Overall the concept of the PepXIM SIM Injector (formally call the SIM Bank) as part of the FusionSIM solution is a great concept. However, it currently lacks the finesse, user-intuitive and integration refinement that is so much a hallmark of equipment from Peplink|Pepwave. To us these are minor shortcomings that can be resolved through evolving the firmware further and improving the solution and integration with the various web admin for the routers and also importantly the platforms of InControl2, SDWC & SIMCloud.
Equipment used with FusionSIM tests and deployment:
2 x SIM Injectors (both badged as PepXIM SIM Bank)
1 x HD2 Dome (customer of @Venn with remote SIMs supplied for AU from @mldowling)
1 x HD4 MBX
1 x PDX with 1 x SFE (HW Ver2) in expansion bay
1 x SFE-CAM (HW Ver1)
1 x Balance Router (Remote SIM Injector hosted behind this)
1 x FusionHub (as an alternative pathway to get the SIM Injector)
Firmware Versions used:
- Remote SIM 2 Firmware Version 1.1.60 PEPXIM SIM injector doesn't seem to save static IP address - #4 by sitloongs
- Firmware 8.1.0 Release Candidate 2 Firmware 8.1.0 RC 2
Existing Support Tickets (know about):
- 20050194 @Jcol7884 Pepwave HD1 Dome with SIM injector not reading SIM´s - #4 by Jcol7884
- 20070228 @mldowling “Unable to get SIM Injector working with SFE” (not previously mentioned in Peplink Forum), ticket assigned to @sitloongs
Reference materials from Peplink Forum:
Search for “SIM Injector” sorted by date
Articles (in acticle # order, generally representative of post published order)
- Introducing the HD2 Dome and SIM Injector!
- (Restricted Inside Forum) https://forum.peplink.com/t/sim-injector-fusionsim-fusionsim-pop-a-quick-guide/20017?u=mldowling
- (Restricted Partner Forum) https://forum.peplink.com/t/sim-bank-and-fusionsim-support/20763?u=mldowling
- SIM injector and HD2 dome stuck on 3G
- Remote Sim Management Menu not appears HD2DOME and SFE - SIM INJECTOR [SOLVED]
- Sim Injector PEPXIM
- Rollover to sim injector
- SIM installation
- Pepwave HD1 Dome with SIM injector not reading SIM´s
- HD2 IP67 with SIM injector
- Using SIM Injector with 2 HD1 Domes
- PEPXIM SIM injector doesn't seem to save static IP address
- Sim injector / remote Sim manager instructions
Platforms
- InControl2
- SDWC
- SIMCloud
The following are our thoughts after an intensive 24+ hours (over the weekend) working at refining some SIM Injectors working across multiple models of equipment:
- Ability to use the remote SIM as a C, the same as using the current A & B SIMs, and there are multiple available remote SIMs, be able to set them up like the A & B SIMs (going A, B, C, D, E, F, …) all with unique options
- Ability to start with off with an internal SIM to establish the connection to remote SIM, collect required details from remote SIM and then switch over to remote SIM
- Ability to enter into the “Remote SIM Host” multiple IPs and domain names for when a device needs to access various FusionSIM Systems
- Ability to use a domain name instead of an IP for the remote FusionSIM system (SIM Injector) such as remotesims.companydomain.com rather than the Public Facing IP
- Ability to define a custom port number for the remote FusionSIM system (SIM Injector)
- Ability to define the APN and other SIM related settings at the SIM Injector to get passed along to the Modem
- Remove the “Remote SIM Management” page within the Advanced Menu and streamline the options within the Cellular Modem settings instead
- Be able to have the SIM Injector/FusionSIM Server work across VPN Technologies such as PepVPN, SpeedFusion, IPSec & OpenVPN
- On the SIM Injector, have the blue circle with the question mark (?) throughout the web admin with helpful information
- Be able to have Trunks and VLAN (differing subnets) on the Ethernet port of the SIM Injector
- Be able to have multiple PepVPNs directly into the SIM Injector
- Be able to isolate/lock SIM Ports to specific devices
- Be able to have a text readable log that can be downloaded from the SIM Injector (current log is scrambled when we attempt to download)
With InControl2 (get this sorted then mirror into SDWC):
- Be able to see the APN details (like the regular A & B SIMs) and other information such as the ICCID of the remote SIM
- Have the event logs of the SIM Injector available with the device on InControl2
- Have the status of the SIMs for the SIM Injector show in InControl2
- Be able to remote web admin the SIM Injector from InControl2
- Be able to set the SIM Injector admin Password using the InControl2 Password Group Policy
- Be able to see on both the web admin and InControl the status of the Ethernet ports
- SIM Injector Configuration Backups are not available within InControl2
- From InControl2 be able to remote reboot the SIM Injector
With SIMCloud:
- Why is not all the information about the SIM Injector being pulled directly from or via InControl2?
- Add on the website Feedback feature (Usersnap) so that issues and questions can be raised directly to the development team as we see on the other web/cloud platforms from Peplink
Missing documentation (or information not found crawling through the forum):
- There is a menu called “Cloud Settings” on the SIM Injector, do we need to be adding in details to this, what is this menu for?
- In SIM Injector FW 1.1.29 there were two options for inbound ports, now with FW 1.1.60 there is only one, why the change?
- Where are the release notes on the firmware updates for the firmware? The latest guide we can find was posted by @Sit on 16 Oct 2019, https://forum.peplink.com/t/sim-injector-fusionsim-fusionsim-pop-a-quick-guide/20017/40?u=mldowling and refers to this document
Quickstart guide for FusionSIM with FusionSIM Controller.pdf - Google Drive
We have done our best to make the most of this technology development, and we wish to actively encourage the Peplink team to develop the FusionSIM solutions to the level, and integration that is seen with so many other systems from Peplink|Pepwave range.
Happy to Help,
Marcus ![]()
