otay
August 26, 2019, 10:25am
1
Hello, Simple question on SIM installation. I have model:MAX HD2 LTEAIP67. Do i need to open the case so I can install SIM card? Concern with Warranty issue.
Thank you,
Tim_S
August 26, 2019, 10:57am
2
Yes you do need to open the case in order to install the SIM cards and this will not void your warranty. Thanks
Hello @otay ,
We can highly recommend using the Peplink SIM Injector with the HD2 Dome.
SIM Injector: Free the SIM Cards From the Router!
Using the SIM injector, you can add an additional eight SIM cards to your deployment. What’s more, these SIM cards can be located separately from the router.
This means you could mount the HD2 Dome outdoors in a high up place, while comfortably managing your SIM cards from an indoor location or from ground level. In addition, the SIM Injector also works as a PoE switch, powering up the HD2 Dome directly.|
[2019-01-22_141314]
We are proud to introduce our newest outdoor cellular router: the HD2 Dome! This router provides dual-cellular SpeedFusion SD-WAN with greater mounting versatility than anything we’ve made before. With its integrated screw mount, you can easily install it on rooftops and on top of poles. With the included mounting bracket, you can to nail it to any wall or tie it to the side of any pole.
The HD2 Dome’s ports are just as flexible. It only needs power from a single 802.3af Po…
Happy to Help,
Marcus
