We are proud to announce the launch of Firmware 7.0.2! This Firmware brings a number of improvements to your router:
- SIM Bandwidth Pooling: Define multiple SIM pools for each IC2 group, and set the pool's bandwidth quota limit. Email notifications are sent once quotas are reached.
- Roaming Country Selection: Added the ability for users to select which countries to enable data roaming using the mobile country code (MCC).
- Guest Protect for AP Controller Lite: The Lite version of the AP Controller now supports SSID Guest Protect for both local AP and external AP.
- IP Passthrough for the Surf SOHO.
Here are the release notes. Head to the download page to try it out, and let us know what you think!
