Peplink seems to be one of the few edge routers that cannot accommodate the Starlink app workaround. When NOT using the included Starlink wireless router, in order to be able to use the mobile app, you need the ability to route 192.168.100.1/32 or 192.168.100.0/24 to the WAN interface but not to the next hop necessarily. I tried all suggestions and tinkered for hours and could not get it to work. I believe a limitation in the routing code will need to be tweaked to allow this.
I imagine Peplink would be a pretty common choice coming up for people in Starlink beta, but not being able to use the app to see statistics is a killer.
Here is a discussion on it: https://www.reddit.com/r/Starlink/comments/jxkz1q/anyone_know_how_to_get_the_starlink_app_to_work/
and here is a Peplink forum discussion on: Starlink and Peplink Balance - #9 by darwinperrier
Odd, they have that functionality for PPOE connections. I imagine this could be fixed in a similar way. I think they call it âManagement IP Addressâ or something like that. It allows for a dsl modem to be managed while in bridge mode.
@sipple31, @jmjones, thank you for bringing this to our attention, the team has reviewed the request and working on the solution. Target to have a special build firmware to address this in the coming days/weeks. Stay tuned.
[Update: 01 April 2021]
The special firmware for the below models can be downloaded here, other models are coming. Please give it a try and let us know the result.
| Balance 210 |
HW4-5 |
| Balance 30 LTE |
HW3 |
| Balance 30 Pro |
HW1 |
| Balance 310 |
HW4 |
| Balance One |
HW1-3 |
| Balance One Core |
HW1 |
| MAX 700 |
HW3-4 |
| MAX BR1 ENT |
HW1 |
| MAX HD1 Dome |
HW1 |
| MAX HD2 |
HW5-6 |
| MAX HD2 Dome |
HW1 |
| MAX HD2 IP67 |
HW2-4 |
| MAX HD2 Mini |
HW1-3 |
| MAX HD2 with MediaFast |
HW1-3 |
| MAX HD4 |
HW1-5 |
| MAX HD4 IP67 |
HW1 |
| MAX HD4 with MediaFast |
HW1-3 |
| MAX Transit |
HW1-3 |
| MAX Transit Duo |
HW1-3 |
| MediaFast 200 |
HW1,3 |
| SpeedFusion Engine Cam |
HW1 |
Steps to enter the Management IP Address:
Enable the feature in DHCP WAN
Input the Management IP:
Thank you for the prompt reply and Iâm happy to assist with testing if you need it⌠
thanks for bringing this up again @sipple31. I believe I saw a post on reddit indicating it might have been pulled in to an upcoming release. i am hopeful they will draw attention to it as the âfixâ for Starlink customers. in the meantime I am considering an option described in another thread here which is to put a dumb switch between the dish and the peplink, and then attaching the starlink router to said dumb switch. will still require jumping onto the starlink routerâs wifi temporarily to grab the stats, but atleast then its possible.
Does it work if you create an outbound policy and put it at the top of the list and turn on expert mode.
Do an enforced 192.168.100.1 via the wan itâs plugged into?
If you read the peplink thread from the first post, you will see that an outbound policy does not work, and that a static route is required.
The simplest workaround is to run your Peplink off the aux port on the Starlink router. This keeps the app working⌠itâs just non-ideal because you have double-NAT, the extra hardware in-between, and a Wi-Fi network clouding up the airspace that you canât turn off.
Was expert mode enabled? It doesnât seem clear in the original post that an outbound policy to ip 192.168.100.1 as an ip or network 192.168.100.0/24 , enforced to the correct wan with expert mode enabled was tried.
Also the tracert showed trying it to the LAN via the WAN.
Can someone please test this and show the screenshots of the configuration?
I have expert mode enabled, it didnât help. When you check the ARP table, there is never an WAN 1 arp entry for
192.168.100.1.
Here is a CLI ping test manually sent out of the WAN interface. This bypasses all questions of Outbound Policy rules.
support ping 192.168.100.1 wan 1
PING 192.168.100.1 (192.168.100.1) from 100.66.32.1 eth1: 56(84) bytes of data.
â 192.168.100.1 ping statistics â
5 packets transmitted, 0 received, 100% packet loss, time 4192ms
A tcpdump confirms that the packets to 192.168.100.1 are sent to the MAC address of the WAN DHCP default router, and since the mac address handing the statistics of the sat terminal is a different mac address from the CGNAT default router handled by the bridged modem there is no response.
? (100.127.255.1) at 02:02:00:00:00:01 [ether] on Starlink
? (192.168.100.1) at 26:12:ac:1a:80:01 [ether] on WAN-EXT
(This is with my dual WAN + switch workaround).
The passive interception of 192.168.100.1 regardless of mac was standard in DOCSIS modems, but many other bridged modems (DSL, Starlink) do not examine the bridged traffic, and only accept management traffic specifically destined for their MAC address.
For these to work, you need to use one of the listed workarounds until Peplink handles static routes on WAN interfaces, or some other way to manually set the mac address of these outbound packets.
If you would like to see the tcpdump I can go generate a fresh one.
I wonder if putting the peplink in drop in mode would help?
I think it does arp proxy.
Youâll have double NAT anyway due to starlinks use of carrier NAT, this would likely be triple NAT but it should in theory still work.
thnx for sharing these detailsâŚ! control cables UAE
Amazing! I am a Starlink beta user. Downloading and installing the test fw now and will report back.
On a Balance One Core, Iâm not seeing the âManagement IP Addressâ field despite being on the latest fw.
I also reloaded the admin portal in private browsing to make sure it wasnât a caching problem or anything.
Update: my router just rebooted again and seemed to revert to the prior FW? Trying the process again now.
New router version seems to be staying now on the 2nd try, however, the Management IP Address field is still MIA.
You need to click on the ? next to the hostname field to enable it.
Ahh thanks! My confusion was that the field already existed in the demo screenshots above.
Awesome! I have a starlink dish myself and itâs been great so far.
