Mobile Network Whitelist via MCC/MNC code
Hi Guys
We do a lot of work within the marine industry (superyachts and large cargo vessels) and supply quite a few of your routers. It would help us greatly if we could set the router to only connect to certain networks around the world. A lot of our solutions only cover certain countries or certain networks within each country. Some of our customers have been receiving large bills by using the wrong network automatically.
If I can help at all with this in any way please let me know.
Matt Parnell
RoamingExpert
Hi Matt,
After having internal discussion, we do have similar feature in our roadmap. However, your request is based on carrier service. This brings us the challenge of showing all the carriers (more than 1600 carriers) in worldwide. Can you share how you preferred the carrier selection to be showing up and allow carrier select from the UI? User experience with the UI is important for us.
Thank you.
Hi TK Liew / Peplink Team
Many thanks for replying.
I was envisaging a list where I add the MCC/MNC codes for the networks I want to be able to connect to one by one then maybe an option in cellular settings where the whitelist can be turned off and on. This way there would be no need to add all the networks on a drop down, for example, and you would not need to keep any lists up to date as new networks are formed. The router when in automatic network selection mode would then look at all the networks it can see and see if any are on the “allowed” list before it connects.
The manual carrier selection option that you currently have is great and does not need changing in any way. We find the scan facility much more useful than manually setting the network via MCC/MNC code which some other makes (e.g. Cradlepoint) employ.
Your UI is the best of the bunch by the way. We have exposure to most of your competitors and yours is head and shoulders above the rest. Automatic firmware update check doesn’t work too well though if you are after feedback - I tend to have to do this manually.
Cheers
Matt
If you are going to add a white list then it would make sense to add a blacklist as well, done in the same way.
Hi Matt,
We target to support this in v6.4.0. Stay tuned.
That’s brilliant guys!! Many thanks. Very impressed.
Anny update on this ? as we are getting the request for this feature more often.
+1 here. Any news on MNC whitelist/blacklist? This is a must have for roaming, as MCC is not sufficient form some customers
MCC is supported from firmware version 7.0.2 onward. Detail info please find using the URL below:
MNC whitelist/blacklist is not available due to some technical challenge. Engineering is reviewing the request and no ETA for now.
Is there any plans/pipelines for implementing MNC whitelist/blacklist to Peplink?
Hi Guys
Thank you very much for this feature. It’s helping us out massively already. I have been doing a little testing in the office and have come across a very strange issue. Am i right in thinking that you cannot blacklist (deny) the home country of a sim? If so, I would imagine this could be changed quite easily. We prefer our sims to always be roaming sometimes.
Cheers
Matt
Hi Roaming Expert,
That is correct, the data roaming options have no effect on the SIM when it is in its home country.
The logic behind this is when a SIM is in the country of origin it isn’t roaming.
If you would like to see this option changed, please raise it as a new feature request.
+1 for MNC as we have the need to force a SIM to a particular carrier while roaming.
Happy to Help,
Marcus :slight_smile:
We also received the request in this minute.
Isle of Man has the same MCC like Ireland, but another MNC. Costs are about 5 Euro for 1 MB on this Island. So blocking this would be nice.
Dennis
In firmware 8.1.0 , You can select the carrier based on the PLMN.
Hi @sitloongs,
that sounds good. Could you please explain this feature a little bit? Does it mean I can whitelist one Provider or more? Can I also use this as a Blacklist?
Dennis
@dennis.hofheinz
We have some discussion here :
Do you think it’s good enough for you to understand the feature ?
Hi @TK_Liew and @sitloongs,
This is a great feature. Could you also make it a blacklist for PLMN codes?
I have a customer that would like to block a certain provider that is charging a lot when roaming on their Cellular towers.
Kind regards,
Dylan van Elst
Is there a manual how to implement this.
I want to black list TDG Germany from using .
My vessels go from Rotterdam Europoort to Swelgrun Germany
Normally they will use O2 / Vodafone or Telkom with have no issue
now they are connecting to TDG and this gives us a lot of problems
to solve this issue i would like to use this Custom PLMN function
Hi Guys
Very urgent.
Am I right in thinking this feature has been removed on the 5G modems? Checked a transit 5G and a Balance 310 5G and this feature is not there. This is a massive problem for us. We need it back ASAP.
@markiequarkie, sorry this is months late but if you need a hand with this message me.
Regards
Matt
