I recently purchased pepwave MAX Transit (MAX-TST-DUO-LTEA-W) with speedfusion bonding licensed installed and activated.
Is it possible to use speedfusion bonding setup from max-transit-router then direct to client(pc/laptop) ?
I need help on how to configure speedfusion bondingdsetup.
current setup: 2x SIM-A & SIM-B (different telco/ISP provider) LTE-A
goal : Bandwidth Aggregation or bandwidth bonding (for 2 SIM) for double bandwidth speed and with uninterrupted data setup (high availability for gaming and zoom meeting).
To use the SpeedFusion bonding feature youâll need to create a SpeedFusion tunnel to another Peplink device - I would recommend using a free FusionHub Solo licence and hosting this in the cloud. @MartinLangmaid has provided instructions to his answer to this question > here <
I registered my peplink device serial number and I got the activation key. Then I went to special addons and add the key for activation but the key is already used SPeedfusion cloud
I was able to activate speedfusion cloud and thanks for that one, BUT my goal is to have a link aggregation for 2 CELLULAR modems (SIMA & SIMB) for double bandwidth speed and high availability purpose.
My Goal : Bandwidth Aggregation or bandwidth bonding (for 2 SIM) for double bandwidth speed and with uninterrupted data (High Availability for gaming and zoom meeting).
@sitchuwap I donât know about your particular hardware or setup, but as long as you leave off the WAN Smoothing option, then SpeedFusion absolutely bonds 2 links together at the packet level⌠IE packet 1 on Link A, packet 2 on Link B, packet 3 on Link A, Packet 4 on Link B, etc for double the throughput in theory. I say in theory because thereâs CPU overhead, packet overhead, another end of the tunnel and lots of variables.
If you are using the SpeedFusion cloud option, there are 2 tunnels, Default and WAN Smoothing⌠just use default.
If you are setting up your own FusionHub, leave off this optionâŚ
Now with all that said Iâve only been able to push about 80Mbps through SpeedFusion cloud or even my own FusionHub server at Azure, versus I get 110-160Mb and 40-80Mb out of my 2 links respectively. So if I use an application that starts 2 data streams and load balance it locally with Weighted Balance Algorithm, Iâm able to get 220MB of download throughput. So I wouldnât say SpeedFusion will fix everything in your life, youâll still have to play around with the trade offs of each solution. For my needs, Iâm using outbound policy to select what goes down the tunnels versus what goes out locally.
I followed the guide for SpeedFusionHub setup but I am NOT able to establish the connection from my max-transit to fusionhub (hosted via google cloud) or vice versa.
The PepVPN with SpeedFusion status is only starting from max-transit and fushionhub.
the status of the devices under incontrol2 portal and I see it is a green status.
If all you see is âstartingâ that typically means that the transit can not commnuicate with google cloud and do a handshake.
Did you open the ports as per: Configuring FusionHub for Google Cloud Engine
Is it possible to have 2 services (SFhub and SFcloud) established and running at the same time without issues?
what will be your best recommendation based from âmy goalâ is it SFhub or SFcloud?
My Goal : Bandwidth Aggregation or bandwidth bonding (for 2 SIM) for double bandwidth speed and with uninterrupted data setup (high availability for gaming and zoom meeting).
Yes. use outbound policy to decide how they are used by your devices / traffic.
Either. both the cloud and the fusionhub have the same features. One is not better than the other. However having your own fusionhub lets you have full control which can be nice.
My recommendation would be to set both WANs in priority 1 on the speedfusion profile then turn on Forward Error Correction (FEC) in that profile. That will be the best balance of bandwidth aggregation and resilience without knowing more about your connections. Then test and test again and tell us how you get on.
What will happen if I already consume my Data usage allowance under SFCloud?
If my FScloud is expired, do I need to purchase new license for it?
how to set unlimited Data usage allowance for FScloud?
That will work. I personally prefer to use priority for fail-over reasons⌠IE if my FusionHub at Azure goes down it will fail-over to T-Mobile in the example below.
regarding FEC , I cannot find it on my current setup, I am using fusionhub as my speedfusion.
Regarding your Source IP address = â192.168.1.70â is that a network device or the IP of the client?
Hello Mark --I too have a Max transit and two carriers in the same device running as Priority One. Did you find out how to get the increased bandwidth you were looking for out of the single device? If so, where did you find instructions to do tis and/or what were the steps you used to make sure you were configured correctly?
