Hi.
I going to buy a Balance 30 Pro, but I am do not 100% convinced about:
SpeedFusion Hot Failover, SpeedFusion Bandwidth Bonding and SpeedFusion WAN Smoothing works over any IP connections? or only works with VPN?
If I buy hardware by amazon; where I can buy the licence for SpeedFusion Suite?
You can use any IP connection to build a VPN tunnel between your B30 Pro and the hosted virtual appliance (Fusionhub).
Fusionhub has a free license (Fusionhub Solo) which you license via InControl2 the management platform.
I made a guide showing how to set up FusionHub here: Setting Up FusionHub on Vultr – Martin Langmaid – SDWAN Architect
Tnks for your answer!
Ok. Rewrite my question: SpeedFusion Smoothing, SpeedFusion Bonding and SpeedFusion Hot Failover, only works in VPN?
Jason
4
–Correct, these are all features of the SpeedFusion VPN.
