How to Upgrade Firmware
Upgrading firmware can be done in one of three ways. Using the router’s interface to automatically check for an update, using the router’s interface to manually upgrade the firmware, or using InControl2 to push an upgrade to a router. Please follow the link for the method relevant to you.
*Please note that upgrading the firmware will cause the router to reboot
Ramiro,
Thanks for excellent tutorial. I downloaded new Soho firmware manually and tried manual update. Downloaded file was .bin not .img and gave error “Invalid firmware image”. I then did automated firmware upgradde and that worked. Method 1 is supposed to be safer as per Michael Horowitz.
