We planning to update 30 units with different firmware and older firmware can we upgrade Pepwave devices
without any problems ? for example from version 6.3.0 to 7.1.0
Special devices as Balance one Core
Yes, you can upgrade Pepwave devices from 6.3 to 7.1.0 without any problems as long as the models are supported by this firmware version.
Please read the following forum post for more information:
Please note that the following models will NOT be supported by Firmware 7 onwards. Rather, they will
receive Firmware 6.x maintenance releases as needed:
You can download the firmware from our website:
Thanks Erik all clear !
Erik_deBie, we have a client with a Balance 20 with a firmware version 5.4.10 that we want to upgrade to 7.1.1. OK to go straight to 7.1.1 or do we need to stair step the updates? Thank you!
Hi @TrinDH,
We would recommend upgrading to 5.3.12 first, then to the latest firmware available to your device - depending on the Hardware Version. This can be found on the Status Tab of the User Interface.
You can download older Firmware from > Here < Select “Balance 20” from the drop down and then download 5.3.12 for the appropriate Hardware Version and apply that you your Balance 20.
Hope this helps,
Steve
In addition to Steve 's advise, be aware that you need a firmware unlock key when upgrading from firmware version 5.x to 6.x.
This post explains how you can obtain your firmware unlock key:
https://forum.peplink.com/t/obtaining-your-free-firmware-license-key/7910
Steve.Taylor, thank you for your reply! To clarify, since the firmware is already higher then 5.3.12, it’s currently 5.4.10 build 1769, should we be OK to upgrade straight to 7.1.1? FYI, the hardware revision is ‘1’ if that affects the result.
Erik_deBie, thank you for that information and the link. I will be sure to do that so we are prepared when we upgrade!
Hi @TrinDH,
Yes, you should be able to upgrade to 7.1.1 - subject to obtaining a licence key, as suggested by @Erik_deBie - it may be worth upgrading to 6.3.4 first, but not essential.
Steve
Steve.Taylor, Thank you! I will post the result once done!
Hello @FL419,
There is one model (with specific Serial Numbers) of the Balance Routers that is recommended to be upgrade with a specific version of firmware before going to Version 7.x or later.
Happy to Help,
Marcus ![]()
