Updating Firmware Using InControl
Method 1a: Updating Device Group Using InControl
On your InControl organization, select the group you wish to update Firmware for. Then use the top bar to navigate to Settings > Firmware PolicyHere you can select which firmware to update on which machines. These configurations will appear in all machines within the group. If you are dealing with a large number of machines, you may wish to use InControl’s firmware scheduling functions. Click Save Changes to complete the process.
Method 1b: Updating Individual Devices Firmware Using InControl
On the individual device page, navigate to Settings > Firmware ManagementFrom there, you can select the firmware you wish to update your device with. Press Save Changes to apply your changes
Updating Firmware Using the Web UI
After login Web Admin of your Peplink/Pepwave unit, go to “System > Firmware”There are two methods to upgrade your Peplink Balance / Peplink FusionHub / Pepwave MAX to the latest firmware:
