I’m looking for the least expensive peplink box to connect to SpeedFusion Cloud, bonding a wired connection and a wireless as wan connection, via a cell phone hotspot.
I’d like to use wan smoothing to replicate a voip phone’s traffic across both links.
Can both a wired wan and wireless as wan connection be active at the same time, connected to SpeedFusion Cloud, on the soho MK3?
Can you please clarify this with regards to the Surf SOHO MK3 in particular? As I understand it, this product only supports PepVPN for site to site VPN connection to other Peplink routers and NOT SpeedFusion. I’ve checked the Peplink product page and there’s no mention of SpeedFusion in the specs there. However, there is a section on VPN that is a bit misleading as it does note SpeedFusion here.
As a follow-up, I purchased a SoHo MK3 to test, and you can bond a wired WAN and WiFi as Wan connection for simultaneous use via SpeedFusion Cloud, on firmware 8.1. I seem to be running into a bug where I can’t enable WAN smoothing, but I see both connections in use at the same time, via the tunnel status page. Very cool!
@mystery, for PepVPN connection, SOHO MK3 supports failover only. You can’t put 2 or more WANs into the same priority in the PepVPN profile.
For SpeedFusion Cloud connection, SOHO MK3 supports SpeedFusion bonding as long as the SpeedFusion Cloud is activated. You can put 2 or more WANs into the same priority in the SpeedFusion Cloud profile.
SOHO MK3 can connect to SpeedFusion Cloud with SpeedFusion Cloud profile and connect to FusionHub Solo with PepVPN profile.
