Hope you can assist or advise, We are experiencing a very High Data usage problem at one of our clients.
The Client have 200 BR1 connected to a Balance in our data Center Via VPN
During non office hours the keep alive data is 5MB per hour per Br1 connected to PepVPN, due to our very restricted and high cost data in our country we need to reduce data usage.
I tried the Following already:
Create Rules to only allow some data in to the VPN like RDP, Printers.
Disabled the security on the VPN
Change the VPN to connection.
Update and block domain names.
Yet we are only saving 3% data.
Incontroll reports that 90% of data is used by the VPN connection
I fond the following cortical of someone that had a problem very similar to mine. There is no feedback on his request.
We made the change and all the devices is now running on V7.1.1 with most Incontroll2 updates stopped. We are still using 5MB of data per hour to keep the PepVPN connection alive per unit.
That sounds like a lot of data to me, but it all depends on your configuration and usage.
Maybe bandwidth reports can help to find out what is using the data?
