[Known Issue] [8.5.2] Device Not Adhered To IC2 - Data Pool Plan Restriction
Ref.: #34072, #33993, #34317, #34107
[Update: 2025-06-23]
For Balance 20X users, if your device is experiencing abnormal behavior, you may want to visit this article for more details.
[Update: 2025-06-11]
To complement the [When Bandwidth Quota Exceeded] functionality, we have added support for the SIM Data Pool or Starlink Data Pool - Bandwidth Throttling feature, on top of the 8.5.2s008, packed in a newer special firmware, 8.5.2s042. It will be included in the next GA firmware release.
The download links below will be replaced with the 8.5.2s042 images, while additional links will be added for 8.5.2s008 images, in case anyone prefers that.
Details [2025-06-09]:
If the SIM Pool feature in IC2 is enabled with [When Bandwidth Quota Exceeded > Stop Routing User Traffic] option checked (shown below), and the devices are running firmware 8.5.2 GA, when the usage is over the quota, the devices will not follow the restriction and continue to consume the data pool.
Affected firmware version:
8.5.2 GA
Fixed in firmware version:
8.5.2s008
Workaround:
We have prepared a special firmware, 8.5.2s008 (based on the 8.5.2 GA) to fix the issue.
The fixes will be included in the next GA firmware release.
At the same time, our IC2 Team also working on an alerting mechanism to display a warning message in SIM pool profiles about this issue if the Org/Group contains devices running firmware 8.5.2 GA.
In addition, this special firmware also added the enhancement to include Starlink data pool - over usage quota restriction (sample below).
Here are the download links for the special firmware (8.5.2s008):
Download Link Product Hardware Revision
Download (s042) B One Series HW1/HW1-2
***fw8.5.2s008 MAX BR1 Pro CAT-20 HW7
MAX BR1 Pro 5G HW1
MAX BR2 Pro HW4
MAX Dome Pro LR HW1
MAX HD1 Dome Pro HW1-2
MAX Transit Duo Pro HW1
Download (s042) Balance 2500 EC HW1
***fw8.5.2s008 Balance 1350 EC HW1
Balance 310 5G HW1-2
Balance 310 Fiber 5G HW1-2
Balance 310X HW1-4
Balance 380X HW1
Balance 580X HW1
Balance Two HW1
EPX HW1
MAX HD2 MBX HW1-4
MAX HD4 MBX HW1-4
MAX MBX Mini HW1
PDX HW1-2
SDX HW1-3
SDX Pro HW1-2
Download (s042) Balance 20X HW1-3
***fw8.5.2s008 MAX BR1 IP55 HW4
UBR Plus HW1
Download (s042) Balance 210 HW4-5
***fw8.5.2s008 Balance 30 LTE HW3
Balance 30 Pro HW1
Balance 310 HW4
Balance One HW1-3
Balance One Core HW1
MAX 700 HW3-4
MAX BR1 ENT HW1-2
MAX HD1 Dome HW1
MAX HD2 HW5-6
MAX HD2 Dome HW1
MAX HD2 IP67 HW2-5
MAX HD2 Mini HW1-4
MAX HD2 with MediaFast HW1-4
MAX HD4 HW1-5
MAX HD4 IP67 HW1
MAX HD4 with MediaFast HW1-4
MAX Transit HW1-3
MAX Transit 5G HW2-3
MAX Transit Core HW1
MAX Transit Duo HW1-3
MAX Transit Duo Pro E HW1
MediaFast 200 HW1,3
SpeedFusion Engine Cam HW1
Download (s042) Balance 1350 HW2
***fw8.5.2s008 Balance 2500 HW1
Balance 305 HW2
Balance 380 HW6
Balance 580 HW2-3
Balance 710 HW3
MediaFast 500 HW1-2
MediaFast 750 HW1
Download (s042) MAX BR1 Mini HW3
***fw8.5.2s008 MAX BR1 Mini 5G HW1
MAX BR1 Mini Core HW3
MAX BR1 Mini M2M HW1
MAX BR2 LTE HW4
MAX BR2 Micro HW1
@PeterWest , @thoffman , @MartinLangmaid , @MarceloBarros , @mldowling , @josh.velling
Please be aware of major bug I found that could cause large overages!
@WeiMing This was a big problem, but thankyou for quickly identifying so we can move on, does bandwidth throttling work in this special build?
@Jonathan_Pitts per the update (above), you may opt for the newer special firmware (8.5.2s042) which includes SIM and Starlink Data Pool - Bandwidth Throttling feature.
@WeiMing the smscontrol menu is missing on this build.
8.5.2s042 build 5929
MAX-BR1-PRO-GLTE-S-T-PRM
@Jonathan_Pitts I checked with the Engineering Team, currently, this cellular module does not support the SMS Control feature.
Current support module (up to firmware 8.5.2).
We are evaluating the feasibility of adding the feature to the module.
If that is possible, we will update the supported module list of the SMS Control Command Reference document.
@WeiMing , and @Michael Are devices on 8.3.0s068 effected by this bug? or was it only devices on 8.5.1?
@Jonathan_Pitts ,
Which device model you are referring and I suppose the issue only happen for device after upgrade to 8.5.2GA.
Any reason to keep such old firmware 8.3.0s068 ? If you arrange to upgrade to the posted firmware, this will make sure everything is working as expected with the latest firmware. This will more better?
Thank You
This is for BR1 mini hw2 as it can’t upgrade past this build except for s277.
@Jonathan_Pitts , if that the case, it’s not related to the issue that posted here.
@Michael Can you confirm the new throttling feature does not prevent management mode from engaging on devices running 8.3.0s068 ?
8.3.0s068 has not yet supported bandwidth throttling for SIM pools. So it will fall back to “Stop routing user traffic”. And no known issue has been identified with the “Stop routing user traffic” feature in that firmware release. Management traffic should be able to get through when the pool quota exceeded.
Thanks for this Michael.
With regards to 8.5.2s008 and greater.
Are we able to define multiple datapools and have it work as expected?
Example
ICCID/IMSI 1GB limit throttle to 1mb/1mb
ICCID/IMSI 5GB limit reserve for mgmt mode.
Let me put in this way. When a pool’s bandwidth quota has, say, only 5 GB left, throttle the bandwidth. When the quota exceeds (i.e. 0 GB left), route management traffic only. Is this what you mean?
Yes so to do that we would need separate data pools correct ?
