HD2 LTEA PoE Input
Hi Team,
I’ve noticed that our HD2 LTEA started up after connecting WAN 1 to PoE enabled switch. All status LEDs went green without any other power source. Is this a hidden feature? The datasheet doesn’t mention PoE In support.
Jakub
It is a happy feature. See MAX HD2 PoE Enable? and HD2 PoE Injector
If memory serves, with sufficient PoE power as input you also get PoE output on the LAN ports.
Cheers,
Z
