Dear, on Peplink website under the page of Max HD2, the code for Power Inject for PoE is ACW-609, but if i download the datasheet of Max HD2 the code of Power Inject for PoE is ACW-622.
Which of these two codes should I use?
thanks
Antonio
thanks
Antonio
@asimula, the ACW-622 should be the correct one, we will update our website to reflect the accurate information. Thanks for bringing it to our attention.
BTW, the ACW-622 is 1x 56V Power Supply that enables 802.3af PoE Output.
thanks Wei Ming.
