We would like to announce that the Firmware 8.1.1 Beta 1 is now available.
Supported models:
X Series, Balance, MAX, UBR, SpeedFusion Engine, FusionHub, Surf SOHO
Supported models:
Dear Peplink-Team, thanks for delivering a new 8.1.1 beta firmware. ![]()
After a first test on a balance one, i found the following issues:
I would really appreciate, if you could please improve this as I often need to use a cell phone/mobile to provide remote support during a business trip.
This is the same for the Incontrol2 web ui: It is absolutely not possible to edit firewall rules via mobile / cell phone using eg safari browser.
See: Firewall rule management in InControl2
Please improve it. ![]()
2) The bug regarding OpenVPN (remote access) and UPnP is still there. Having OpenVPN-Server activated on Balance one, our XBoxes cannot open ports using UPnP and claim NAT to be „moderate“. After disabling OpenVPN-server, the Xbox states the NAT to be open. Additional problem I found with this new beta firmware is, that ports are opened by the XBox via UPnp but are not shown in UPnP status. Screenshots (Xbox is German language):
Issues 2) and 3) where already investigated by Rokas from support team some weeks ago based on tickets I opened.
Kind regards
Dear Peplink Team:
Greetings, I am a first-time Peplink Forum poster. Soho MK3 failed to upgrade to Firmware 8.1.1 Beta 1 (4967).
The process appeared to have run properly but Firmware 8.1.0 4941 remains running after reboot. Please also note that System > Reboot > Firmware 2 has changed status to “[Non-bootable]”.
System appears to remain stable on 8.1.0 4941 as before firmware 8.1.1 Beta 1(4967) upgrade attempt. Please advise.
Thank you,
Nick
The reported issue will be addressed in firmware 8.1.1 beta 2.
For now, you can recover the [Non-bootable] partition by upgrade the SOHO MK3 device using the followings firmware.
https://download.peplink.com/firmware/br1ac/fw-max_br1mk2_hotspot_sohomk3-8.1.0s027-build4947.bin
Please provide the upgraded device API documentation for testing.
Thanks !
Dear sitloongs, Peplink Team:
Thank you very much for the information and for the link to firmware 8.1.0 (4947)!
Kind regards,
Nick
Bug report: “Auto” Channel Width setting for AP does not appear to save. It always resets back to 20 Mhz for both 2.4GHz and 5GHz channels.
Can i have your device model ?
We are working on the API document for the new changes and we will post the update again when it’s ready.
MAX Transit LTE-A HW Gen 2
Let me verify and get back to you.
Confirmed this is the firmware bug. Engineering team is working on the fix. Thank you for joining the beta firmware test.
My pleasure. Thanks for the quick response & investigation!
Hello Peplink Team,
Does this new version/beta release support the cellular 5G chipset frequency selection on the Device settings and also the related 5G reporting back into InControl2? We have several systems under test and can upgrade them if it does to the beta release, else we will stay on the current GA release.
Appreciate your assistance,
Marcus ![]()
Release notes will include all the feature improvement for the firmware. I have checked on that I don’t find any on that. ![]()
Seems to have reintroduced the issue previously fixed here: Balance 20 - 8.1.0 - unstable - #26 by TK_Liew
The fixes in the 8.1.0s083 is not fully integrated into the 8.1.1beta1 firmware. Targeted it will be included in firmware 8.1.1beta2. ![]()
Noted. Thanks.
