Firewall rule management in InControl2 allows you to upload a configuration file saved from a device, view or optionally change the rules’ schedule, and then apply these rules to one, or multiple devices.
To configure the Firewall rules:
Configure the Firewall rules on the web admin interface of one of your Peplink routers.
A window will pop up showing all the Firewall Rules available in that configuration file.
This will create a new Firewall Rule Set when saved.
Before saving select the options to enable or disable individual firewall rules.
Select if the rule set should be applied to All Balance and Max devices or a selection of your devices using ‘tags’.
Glad this was implemented but wonder if there is anyway to make changes outside of the GUI. If we could just export the rules as a text file so we can edit it much more efficiently. I ask because I made a bunch of rules in the wrong section (inbound vs internal for PepVPN rules) and can’t move them between the firewall sets.
At the moment there is no way to make the firewall changes outside of the GUI and no immediate plans to implement this.
Importing text files would leave more room for errors since the firewall rules config needs to be in a specific format, but if you have suggestions for improving the way this could work please add your request as a post to the “feature request” category.
Dear @Erik_deBie,
InControl2 is a great tool, that I appreciate.
However, it is absolutely not possible to edit InControl2 firewall rules via mobile / cell phone using e.g. iOS 14 Safari browser.
Navigation in InControl2 works great, but the content pages are not caring for the display size of a mobile device / cell phone with limited display size using it and zooming is not possible (webui directly resizes back to oversize). E.g. on a iPhone 8+ the content is mostly only half visible and I need to slide right left to use the web ui as zooming is not possible, unfortunately.
Scrolling is not possible in many cases as it leads to resorting of the firewall rules (unintentionally).
I would really appreciate, if you could please improve this Web UI as I (and surely many other users) often need to use a cell phone/mobile to provide remote support during a business trip.
Thank you! Kind regards.
Screenshot:
I no longer work for Peplink, I now work for Slingshot6.
Raising your request in the feature Request category on the forum is your best option to get a new feature or new functionality implemented.
The IC2 team have developed an InControl app aimed to be used on mobiles, but it doesn’t have all the options that are available in the InControl web application.
