4828 - [QoS]β Added the ability to rename QoS User Groups
I have just looked on both a MBX and SDX and its not possible to rename
No PL-Feedback to my post? ![]()
i have tested the beta only short, but the vpn connection between a transit duo and my fusionhub went down without any real issues. i needed the setup again for full operation, so i went back to the current stable. maybe someone else also saw such an issue?
I think we missed your post that thinking you are following with Support team. For item 1, we will further test on it and update again.
Do you have diagnostic reported download from the devices when you see the problem ? If yes , can you please open a ticket for support team to review the logs ?
Hereβs an interesting one. Using 8.1.1b01/4976 on a Max Mini LTEA. After obtaining a license key for SFC and configuring the GUI shows the following. Note that the lower left corner where the legend is normally located is a solid black rectangle.
I also saw the same thing.
I tried it on a BR1 MINI LTE.
This is acknowledged. We will feedback to the engineering team. Thanks for reporting this.
