We’re happy to announce that the Firmware 8.1.0 Beta 1 is now available.
Supported models:
X Series, Balance, MAX, SpeedFusion Engine, FusionHub, Surf SOHO
Supported models:
6181 [NTP Server] Added support for NTP Server
squeals in stratum 2
22032 [NetFlow] Added NetFlow Support
squeals in UDP
22430 [E-mail Notification] Added support of STARTTLS All Models
squeals in SMTP
For the netflow feature is it the session logging in System/Event log?
Great to see Netflow added, cant wait to test that out.
Hello @Lai,
Great to see the refreshed changes coming through with the new firmware.
A few early bugs/issues/thoughts to report:
With the new SpeedFusion performance page, it is nice, and we’re with @MartinLangmaid on it though it needs some work on the scale to fit more dynamically into the various web browser screen sizes. These images are for a PDX with four cellular modems, as you can see it would be good to turn off the WANs that are not in use and choose the WANs you wish to focus on monitoring.
We liked the return to the Dashboard after applying changes as we could see the status of the changes getting done (by looking at the CPU) and the overall status of the device. We would prefer to have an option to view a list of pending changes before applying (just our thoughts on the change).
Was also looking for options around the new NTP Feature, where can we find more details and controls for this? Here is our previous post on the new NTP Feature.
We have deployed the Beta release to several devices (several FusionHubs, several models of MAX routers & several models of balance routers) with some of our willing clients on Tuesday morning, no other issues to report at this stage. We are planning to deploy and check soon on an SDX & EPX.
Happy to Help,
Marcus ![]()
You can enable the Netflow feature from the support page. It is currently available for x86 and powerpc devices only.
Thanks Marcus for your feedback. Could you please elaborate on the issues that you see with the Content Filtering options. Also, it would be really helpful if you could create a ticket for it, so we can troubleshoot the issue that you are running into.
Shivani
Hello @shivanik,
Ticket 20050308 created as requested.
Happy to Help,
Marcus ![]()
We will work with you via ticket. We may need to check from your device to confirm the issue.
can you detail which models are on x86/PowerPC?
We have found that an unstable LAN/Wi-Fi network connection is causing the Content Filtering issue. The two laptops used for testing each have their own internal SIMs and were getting their DNS records from that SIMs connection due to the issue with either the LAN or Wi-Fi connection. When the internal PC SIMs were disabled, and the only option was through the routers (LAN or Wi-Fi), the Content Filtering appeared to be working correctly. We note that we had not seen this with other versions of firmware (i.e. 8.0.2) on either of these two PCs and will work with Peplink in the existing ticket to verify if it is a fault with our hardware or a new firmware issues.
Another bug/issue/thoughts:
Happy to Help,
Marcus ![]()
Would you able to elaborate more for this ? Do you mean the PC have it own connection ?
We will wait for the access and investigate on it. Just for your info, we have perform a lab test and the content filtering is working as expected. We may need to check from you device for the reason why it’s not work as expected .
Do you have detail steps for this ? Suppose if the Cellular module will reload the SIM when detected a new SIM card inserted.
What are the steps to enable Netflow? I dug around in the UI and cannot find the page.
login to the web ui, then change index.cgi to support.cgi in your addressbar and scroll to the bottom of that page to find the netflow bit:
