Firmware 1: [Non-bootable]
I’ve noticed this in ‘System’ and I’m presuming it is preventing me from upgrading to Firmware 8.0.2…
Select the firmware you want to use to start up this device:
Firmware 2: 8.0.1 build 1469 (Running)
Why would Firmware 1 be non-bootable? Is there anything I can do instead of opening a ticket please?
@brill
This is a unknown condition for the boot partition. Please open a support ticket to allow support team to check on this .
Same issue here that you failed to upgrade the firmware ?
Yes that’s the same issue. Apologies as things have been extremely busy these last few months. I will try and get a ticket raised ASAP.
I am having the same issue upgrading four of my six devices from 7.1.2 to 8.0.2
I too have the same issue!
@wingerter_1 and @Gsa396. As mentioned by @sitloongs, please open a ticket for us to take a closer look.
Thanks.
I am encountering the same issue while trying to upgrade firmware on Surf SOHO mk 3 from 8.0.0 to 8.02.
Firmware will not update with InControl2 or web interface.
When attempting to re-boot, the following options are presented:
Firmware 2: 8.0.0 build 1429 (Running)
If you loaded another firmware such as 8.0.0, would that push 8.0.2 back into the Firmware 1 position?
@winchesterv
Found that you have opened a ticket for the issue. Support team will check on that.
