Newby here, new Pepwave Surf Soho in home situation. I’m in the country, I have Sprint Pocket Hotspot as my internet source, this is the ZTE MF975S.
I have the Soho setup to use the Wi-Fi WAN as the internet source. The Soho keeps dropping the connection to the Hotspot, on the Events log it says: wpa: authentication timeout
It’s happening as often as every 5-7 minutes, it hooks back up but takes a minute or so each time.
I cannot figure out how to fix this, I don’t see any references anywhere to this anywhere. Any help is appreciated, I did install the 7.0 firmware, btw.
Thanks, will do. I actually want to set this up to usb tether with the ZTE hotspot. I understand this can be done remotely but I need to be in a place with stable dsl or other CAT5 internet, right?
And do a support ticket with the serial numbers and so forth?
Still getting drops every 3-4 minutes. Any way to fix this? I have no convenient way to get these devices to a place with non-firewalled Cat5 internet access for the USB modem conversion.
Can this possibly be done over the existing hotspot?
Jan 31 07:15:05 Admin: admin (192.168.50.10) login successful
Jan 31 06:03:03 WAN: Wi-Fi WAN connected to 4GWiFi (192.168.128.12)
Jan 31 06:02:50 WAN: Wi-Fi WAN fails to connect 4GWiFi (WPA: authentication timeout)
Jan 31 06:02:36 WAN: Wi-Fi WAN disconnected
Jan 31 06:01:57 WAN: Wi-Fi WAN connected to 4GWiFi (192.168.128.12)
Jan 31 06:01:44 WAN: Wi-Fi WAN fails to connect 4GWiFi (WPA: authentication timeout)
Jan 31 06:01:29 WAN: Wi-Fi WAN disconnected
Jan 31 06:00:33 WAN: Wi-Fi WAN connected to 4GWiFi (192.168.128.12)
Jan 31 06:00:20 WAN: Wi-Fi WAN fails to connect 4GWiFi (WPA: authentication timeout)
Jan 31 06:00:05 WAN: Wi-Fi WAN disconnected
Jan 31 05:58:37 WAN: Wi-Fi WAN connected to 4GWiFi (192.168.128.12)
Jan 31 05:58:25 WAN: Wi-Fi WAN fails to connect 4GWiFi (WPA: authentication timeout)
Jan 31 05:58:10 WAN: Wi-Fi WAN disconnected
Jan 31 05:57:41 WAN: Wi-Fi WAN connected to 4GWiFi (192.168.128.12)
Jan 31 05:57:28 WAN: Wi-Fi WAN fails to connect 4GWiFi (WPA: authentication timeout)
Jan 31 05:57:14 WAN: Wi-Fi WAN disconnected
Jan 31 05:55:20 WAN: Wi-Fi WAN connected to 4GWiFi (192.168.128.12)
Jan 31 05:55:06 WAN: Wi-Fi WAN fails to connect 4GWiFi (WPA: authentication timeout)
Jan 31 05:54:52 WAN: Wi-Fi WAN disconnected
Jan 31 05:51:23 WAN: Wi-Fi WAN connected to 4GWiFi (192.168.128.12)
Jan 31 05:50:38 WAN: Wi-Fi WAN fails to connect 4GWiFi (WPA: authentication timeout)
Jan 31 05:50:22 WAN: Wi-Fi WAN disconnected
Jan 31 05:49:53 WAN: Wi-Fi WAN connected to 4GWiFi (192.168.128.12)
Jan 31 05:49:07 WAN: Wi-Fi WAN fails to connect 4GWiFi (WPA: authentication timeout)
Jan 31 05:48:52 WAN: Wi-Fi WAN disconnected
Jan 31 05:48:23 WAN: Wi-Fi WAN connected to 4GWiFi (192.168.128.12)
I would check to see if there is a firmware update available for your hotspot. You should also do a temporary test with no security enabled and see if it works.
I don’t know about your specific device, but my Mifi card has an option that tells whether it will allow tethering or not. It also has the option to disable the wireless LAN if tethered or not. Have you checked for any settings like this?
Still getting the same drops, even with wifi security turned off. Drops every 3 minutes or so, pretty hard to tolerate.
2/23/2017 Web Admin SURF_SOHO_CC5F http://192.168.50.1/cgibin/MANGA/index.cgi?mode=config&option=utlog 1/1
Dashboard Network Advanced AP System Status Apply Changes
Status
Device
Active Sessions
Client List
OSPF & RIPv2
Event Log
Bandwidth
RealTime
Hourly
Daily
Monthly
Logout
Device Event Log Auto Refresh
Feb 23 17:10:04 Admin: admin (192.168.50.10) login successful
Feb 23 17:04:49 WAN: WiFi WAN connected to 4GWiFi (192.168.128.12)
Feb 23 17:04:38 WAN: WiFi WAN fails to connect 4GWiFi (WPA: authentication timeout)
Feb 23 17:04:23 WAN: WiFi WAN disconnected
Feb 23 17:04:00 WAN: WiFi WAN connected to 4GWiFi (192.168.128.12)
Feb 23 17:03:48 WAN: WiFi WAN fails to connect 4GWiFi (WPA: authentication timeout)
Feb 23 17:03:33 WAN: WiFi WAN disconnected
Feb 23 17:01:45 WAN: WiFi WAN connected to 4GWiFi (192.168.128.12)
Feb 23 17:00:37 WAN: WiFi WAN fails to connect 4GWiFi (WPA: authentication timeout)
Feb 23 17:00:22 WAN: WiFi WAN disconnected
Feb 23 17:00:01 WAN: WiFi WAN connected to 4GWiFi (192.168.128.12)
Feb 23 16:59:47 WAN: WiFi WAN fails to connect 4GWiFi (WPA: authentication timeout)
Feb 23 16:59:31 WAN: WiFi WAN disconnected
Feb 23 16:59:11 WAN: WiFi WAN connected to 4GWiFi (192.168.128.12)
Feb 23 16:58:58 WAN: WiFi WAN fails to connect 4GWiFi (WPA: authentication timeout)
Feb 23 16:58:46 WAN: WiFi WAN disconnected
Feb 23 16:58:23 WAN: WiFi WAN connected to 4GWiFi (192.168.128.12)
Feb 23 16:58:08 WAN: WiFi WAN fails to connect 4GWiFi (WPA: authentication timeout)
Feb 23 16:57:56 WAN: WiFi WAN disconnected
Feb 23 16:57:28 WAN: WiFi WAN connected to 4GWiFi (192.168.128.12)
Feb 23 16:57:16 WAN: WiFi WAN fails to connect 4GWiFi (WPA: authentication timeout)
Clear Log
Device Event Log
I used an alternate wifi hotspot, getting the exact same message:
Feb 24 14:58:42 System: Time synchronization successful
Feb 24 14:53:54 WAN: Wi-Fi WAN connected to SprintHotspot2.4-94F8 (192.168.128.12)
Feb 24 14:53:35 System: Time synchronization fail
Feb 24 14:53:09 WAN: Wi-Fi WAN fails to connect SprintHotspot2.4-94F8 (WPA: authentication timeout)
Feb 24 14:52:57 WAN: Wi-Fi WAN disconnected
Feb 24 14:52:29 WAN: Wi-Fi WAN connected to SprintHotspot2.4-94F8 (192.168.128.12)
Feb 24 14:52:17 WAN: Wi-Fi WAN fails to connect SprintHotspot2.4-94F8 (WPA: authentication timeout)
Feb 24 14:52:02 WAN: Wi-Fi WAN disconnected
Feb 24 14:51:39 WAN: Wi-Fi WAN connected to SprintHotspot2.4-94F8 (192.168.128.12)
Feb 24 14:50:12 WAN: Wi-Fi WAN fails to connect SprintHotspot2.4-94F8 (WPA: authentication timeout)
Feb 24 14:50:01 WAN: Wi-Fi WAN disconnected
Feb 24 14:49:24 WAN: Wi-Fi WAN connected to SprintHotspot2.4-94F8 (192.168.128.12)
Feb 24 14:48:39 WAN: Wi-Fi WAN fails to connect SprintHotspot2.4-94F8 (WPA: authentication timeout)
Feb 24 14:48:25 WAN: Wi-Fi WAN disconnected
Feb 24 14:48:03 WAN: Wi-Fi WAN connected to SprintHotspot2.4-94F8 (192.168.128.12)
I apologize but I have never used the wifi wan feature. Make sure that you subnets do not overlap. It looks like the wifiwan address is a 192.168.x.x. If the subnet mask on that connection is 255.255.0.0 - try changing your LAN addresses to a 10.1.1.1 with a 255.255.255.0 subnet. If there are subnet boundary conflicts, I can see the device having a hard time coping. Again, I don’t have one of those devices to validate - but I assume it has a wan and a LAN side - they need to be exclusive (no shared address space)
Someone please enlighten both of us if this is incorrect.
