Hello? Is there anyone who can point me in the right direction?
Wi-Fi WAN on 2.4GHz does not stop “Scanning…”
I work from an RV and aside from cellular service, I need to be able to connect to Wi-Fi WAN for internet connectivity (especially while traveling in Canada) where I will be stationary for the next two months.
Equipment in the RV:
Router: MAX-TST-GLTE-G-T-PRM
Hardware revision: 2
Firmware: 8.0.2s091 build 4467
Enabled: Wi-Fi WAN on 2.4GHz (for trouble shooting to isolate connection)
I am trying to connect to the broadband Wi-Fi at my In-Law’s house. This is the configuration in the house:
SSID: lacroix
Signal Strength: -74dBm, (broadcasting on Channel 4)
Wireless Security Authentication: WPA-PSK and WPA2-PSK
Wireless Mode: 802.11b/g
Gateway Address: 172.16.1.254
Subnet Mask: 255.255.255.0
DHCP Info:
Range 172.16.1.63 - 172.16.1.253
Allocated: 16
Remaining: 175
Timeout: 1440 Minutes
IPv6: Disabled
Occasionally, I see an entry in the event log:
WAN: Wi-Fi WAN on 2.4GHz fails to associate lacroix (WPA:shared key may be incorrect)
The shared key is correct (that’s how I am connected to write this post)
I have tried the following:
Rebooting the Pepwave
Static IP Address
Changed Operating Country in AP settings to Canada (No Clue why this would help, but hey could it hurt?)
Just can’t get a connection nor anything that will indicate what i’ve done wrong.
