Web Password Reset
Please help me to reset webadmin password without changing settings.
If your device is enrolled in InControl2 then you can change the password from there.
Which device?
If you can’t reset from incontrol, I found with a balance without LCD, holding the reset button briefly reset the admin password without doing the full factory reset. Holding it longer (10 seconds – I’m not sure the exact duration) resets it fully I believe. Double check before doing so.
See:
