WAN-Smoothing for several connections
Hi!
I want to use WAN-Smoothing for some critical connections. Is it possible to “smooth” only VoIP-Connections or connections from some IPs, or does this always affect everything that passes the SpeedFusion-tunnel?
Thank you for your help
KPS
Hi KPS,
You certainly can use WAN smoothing for certain connections , protocols or ports as described in this forum post.
Regards,
Erik
Hi Erik!
Thank you very much - great news!
Just one thing: does this setup “count” as one license or two tunnel-licenses?
SpeedFusion license is counted by the number of active SpeedFusion profiles, not the tunnels.
