Has anyone successfully established VPN tunnels between a Peplink Balance and the Amazon AWS (VPC) cloud? I am able to establish the IPSEC link but not able to route between AWS and my local network.
Firmware
7.0.2 build 2167
Any help would be greatly appreciated.
Warren
              I solved my issue, my firewall was blocking access.
              Hi Warren,
For future reference it might be useful to spin up a Fusionhub virtual in AWS
    FusionHub is the virtual SpeedFusion appliance from Peplink which allows you to establish SpeedFusion connections between cloud servers and physical Peplink devices, among those supported is Amazon Web Services/AWS.
UPDATE:  here’s a new simplified approach to install on AWS outlined here-
https://forum.peplink.com/t/deploying-fusionhub-from-aws-marketplace/28571
(Part A) Acquiring FusionHub Instance
Note/Update on June 2020:
You are now able to acquire the FusionHub instance from AWS Marke…
Erik
