BR1 is on Boat, and harbor give wifi access , i would configurate my BR1 for use this wifi access like wan wifi , but this wifi from harbor have captive portal .
How i can configure my BR1 for connect at this wan access wifi with captive portal?
Disable Health Check on WiFI-WAN, set it as P1 on the dashboard with everything else lower priority, connect wifi wan to the harbour wifi.
Then connect a device and try and access the internet. The harbour wifi captive portal will come up do when you need to do there and from that point onwards - once you’re connected to the internet, any device connected to the BR1 will likely also have internet access.
Make sure DNS settings are set to default/obtain from that WAN with the captive portal and not hard coded as external DNS servers may not be accessible while in a ‘walled garden’
