A flexible rule-based configuration design enables the fine-tuning of outbound traffic at a per-service level by allowing multiple rules to be configured.
The following types of Outbound Traffic Rules are available:
- Weighted Balance
- Persistence
- Enforced
- Priority
- Overflow
- Least Used
- Lowest Latency
Weighted Balance
Weighted Balance rules enable configuring the proportion of outgoing data traffic to be handled by each WAN link. (Examples follow.)
Persistence
Persistence rules make specified types of traffic (eg: HTTPS) to always be routed through a particular WAN link based on source or destination IP address(es).
Enforced
Enforced rules result in the routing of specified type(s) of traffic through a particular WAN connection or VPN connection, regardless of its up/down status. (An example follows.)
Priority
Priority rules specify the order of the available WAN links (or VPN connections) in which traffic is to be routed. A priority value is configured for each WAN link; the highest-priority available WAN link will be utilized; lower-priority WAN links will be utilized in priority sequence in the event of WAN link unavailability.
Overflow
Traffic will be routed through the healthy WAN connection that has the highest priority and is not in full load of downlink bandwidth. When this connection gets saturated, new sessions will be routed to the next healthy WAN connection that is not in full load.
Least Used (Balance 20/30 require firmware 6.2.2 or above)
The traffic matching this rule will be routed through the healthy WAN connection with the most available down link bandwidth.
Lowest Latency (Balance 20/30 require firmware 6.2.2 or above)
The traffic matching this rule will be routed through the healthy WAN connection with the lowest latency. Periodic latency checking packets are sent to the WAN connection.
Outbound Traffic Management Interface
The following screenshot illustrates the Custom Rule configuration interface available at Network > Outbound Policy:
The top-down order of the list denotes the order of decreasing precedence. The up and down arrow keys can be used to move a rule up and down within the list, respectively.
Example 1 – Setting up Weighted Balance Rules
The basic idea behind Weighted Balance rules is to govern how Peplink Balance distributes outgoing traffic requests across multiple WAN links.
To illustrate, with the following link configuration:
- WAN1: 3M (DSL)
- WAN2: 2M (E1)
- WAN3: 3M (DSL)
- Service: General
- Source & Destination IP: Any
- Protocol & Port: Any
- Algorithm: Weighted Balance
- Load Distribution Weight: 3 : 2 : 3 (Derived from 3M : 2M : 3M)
Example 2 – Setting up Per-service Weight Balance Rules
Some types of WAN links have different upstream and downstream speeds (e.g. ADSL with 3M upstream and 512K downstream). In such cases, upload-intensive services may require special fine-tuning.
A common example is outgoing email (SMTP), where traffic is mostly upstream.
Building upon the previous link configuration:
- WAN1: 3M Downstream, 512K Upstream (DSL)
- WAN2: 2M Downstream, 2M Upstream (E1)
- WAN3: 3M Downstream, 512K Upstream (DSL)
- Service: SMTP
- Protocol & Port: TCP 25
- Load Distribution Weight: 1 : 4 : 1 (Derived from 512K : 2M : 512K)
To configure Peplink Balance to restrict IPSec VPN traffic to WAN1, add the following per-service Enforced rules:
Rule to specify UDP Port 500 traffic:
- Service Name: UDP500_on_WAN1
- Protocol & Port: UDP 500
- Algorithm: Enforced
- Enforced Connection: WAN1
- Service: UDP4500_on_WAN1
- Protocol & Port: UDP 4500
