Unable to pass L2 (multiple VLANS) Traffic from SFH Solo installed in DC to Remote Pep
Successfully got my SFH running on Proxmox thanks to this post
Added a second NIC for the SFH LAN side connection. However, when the HUB LAN is connected to my upstream router at my core and a SF tunnel with L2 bridge is created from HUB to remote, I am unable to access VLANs from the HUB on the remote side.
Design:
IPs: 10.10.X.1/24
X=VLAN ID
CORE (VLAN 60,61,62,63)-> SHF LAN-> SHF WAN> SF Tunnel w/ L2 Bridging-> MAX PRO DUO WAN-> MAX PRO DUO LAN β†’ LAN (VLAN 60,61,62,63)
Any assistance here will be largely appreciated
Is your LAN side Linux bridge set to be vlan aware?
It’s set to vlan aware ok the Lan NIC. Do I need to do the same on the wan ?
Just on the proxmox bridge connected to the LAN of the Fusionhub.
Martin,
Still having issues here, any additional suggestions ?
Adding a small diagram for reference
Never got this config working
