I have a FusionHub setup on EC2 instance, per Peplink instructions. I have a Pepwave MAX HD4 connected to this FusionHub, and have successfully used it a lot for encoding video with Bonding & WAN smoothing. I’m only using the FusionHub to bond 4 cellular modems into 1. Nothing crazy.
Now I need to port forward incoming UDP 8601 for a special video decoder unit. I have tried various configs and can’t get it to work. I have this successfully working at our office, using Ubiquiti, so I know the video transmission equipment is working just fine.
Where exactly do I need to setup my incoming port forward rules? AWS EC2, FusionHub or Pepwave MAX HD4? And should I apply those rules to every interface? I must admit, when it comes to port forwarding, I’m only used to dealing with one router.
I need some suggestions on whether or not FusionHub and/or Pepwave MAX HD4 should be in NAT mode. Also, do I need to go through each cellular modem WAN on the Pepwave and choose Port Forward instead of NAT under the Routing Mode?
There are so many layers with the SpeedFusion setup. I recognize the layers, but I’m not sure where rules should get applied. And the other two just remain completely open to the world?
