This guide is meant for customers who wish to experience SpeedFusion as quickly as possible.
Requirements
To experience SpeedFusion, you need to gain access to two Peplink/Pepwave Routers. If you do not have two Peplink/Pepwave Routers, you can obtain a FusionHub evaluation license. For this example, we will be using a MAX HD2 (device A) on one end and a FusionHub (device B) on the other.Configuring Device A
1) Copy the serial number from Device B (FusionHub in this case)
- Go to Advanced > SpeedFusion, click New Profile.
Note: if you are using a Balance router, go to Network > VPN > SpeedFusion.
- Configure your device
- Choose a name for your VPN (FH Connection).
- Enter the serial number from device B as the Remote ID (1179-4F53-F5AB).
- In the Remote IP Addresses field, enter the IP address of device B (10.10.11.101). You only need the IP address of one end of your SpeedFusion tunnel. Please remember to remove "http://" from the IP address.
- Click Save.
- Click the “Apply Changes” button on the top right corner.
Configuring Device B
1) Copy the serial number from Device A (MAX HD2 in this case)- Go to Network > SpeedFusion, click New Profile.
Note: if you are using a MAX router, go to Advanced > SpeedFusion.
- Enter the serial number from device B as the Remote ID (2830-CFD8-B336).
- Click Save.
Congratulations, you have now established a SpeedFusion connection! You can check the status of the connection on the dashboard of each device.
