Hello
in a balance 20, I have this in the event log :
System: Applying configuration patch(es) P20190130001,P20190808001
what does that mean ?
regards
poc
Hello
regards
poc
The message comes from InControl. The patches are for fixing some errors or mistakes in the device’s configuration generated by previous releases of InControl. You may refer to this article for the patches’ description.
You may refer to the following organization setting in InControl:
