Sometimes, we might discover previous releases of InControl have generated incorrect configurations to devices. In order to fix the issues, newer releases of InControl unavoidably have to make some changes to devices. We call the changes as “configuration patches”. Below are a list of the patches.
By default, they are applied to devices automatically. You may review the setting “Auto apply configuration patches to devices” under Organization Settings.
Patch ID | Description |
P20190130001 | Fixed “CLI SSH & Console” setting under “Device Web Admin Management” |
P20190130002 | Fixed “Terminate Sessions on Link Recovery” setting in “Outbound Policy” rules |
P20190131001 | Fixed unlimited or missing “Web Session Timeout” time under “Device Web Admin Management” > “General” |
P20190131002 | Fixed “PepVPN / OSPF / BGP / RIPv2 Routes” order under “Outbound Policy” when the default rule is “Auto” and PepVPN Management is enabled. |
P20190131003 | Fixed read-only user’s password when “shared password for all devices” is chosen on “Device Web Admin Management” > “General” |
P20190222001 | Fixed: the NAT setting in PepVPN profiles was always disabled unless the “Untagged VLAN” was selected as the “Hub VLAN” and its DHCP service was enabled. |
P20190304001 | Fixed: failed in applying client MAC address based access control on Wi-Fi AP’s SSID |
P20190306001 | Fixed: a few extended DHCP options were not applied to devices in the correct format |
P20190306002 | Fixed: “Send all traffic to hub” option didn’t generate the additional settings necessary to send all traffic to the DR hub in case of primary hub failure. |
P20190306003 | Removes an unnecessary configuration tag when “Security” is set to “HTTP” under “Device Web Admin Management” > “Peplink Balance/ Pepwave MAX / Peplink FusionHub Specific”. |
P20190414001 | Fixes duplicate PepVPN link configuration identifiers. Duplicated identifiers will interfere with PepVPN link establishment. |
P20190430001 | Removes some unnecessary captive portal settings for devices with no “logout kick” support. |
P20190430002 | Fixed: Passthrough domains order for captive portal was not consistent |
P20190503001 | Fixed: “Discover Nearby Networks” in Radio Settings may not be applied correctly |
P20190530001 | Fixed: “VLAN management” visibility in Firmware 7.1.0 or below |
P20190618001 | Fixes handling of “Suppress Endpoint IP’s” in PepVPN management |
P20190619001 | Fixed: For devices that hit a firmware bug, InControl 2 may remove their reserved IP addresses in device-managed DHCP server settings. |
P20190725001 | Removes redundant LACP settings from the configuration |
P20190725002 | Fixes the shared key setting of SSID’s where the key is configured to be ‘Last 8 octets of LAN MAC address’ |
P20190808001 | Fixed: web admin user name setting missed from the configuration |
P20190816001 | Fixed: an invalid WPA PSK value is set when ‘Open - No Encryption’ mode is selected |
P20190916001 | Fixed: Missing firewall log = ‘no’ if firewall log is disabled |
P20190916002 | Fixed: RSSI threshold setting on 5GHz band of AP One was not effective. |
P20190916003 | Fixed: When a PepVPN endpoint has a DDNS name defined, the hub site will not receive the endpoint’s IP addresses but DDNS name only. This will reduce unnecessary PepVPN connection interruptions upon any endpoint IP address changes. |
P20190923001 | Fixed configuration when all Wi-Fi AP channels are selected |
P20190927001 | Fixed: Removes unused configuration settings |
P20191008007 | Fixed: Repairs invalid latency-cutoff related settings |
