SurfSOHO as a managed switch and Access Point
Now that I have very happily replaced my SurfSOHO with a B-One, is it possible to recommission the Surf SOHO to run as a managed switch and access point?
I am doing something similar with an old Netgear router by running it in access point mode. Would like to get rid of that and replace with the Surf SOHO IF I can take advantage of VLAN support also.
Hello, @chris_heard
Your old Surf SoHo, not support Synergy mode.
So… You can keep using it… but should do the configurations manualliy.
Looking at the Surf SoHo datasheet it can support vlan.
