What is Synergy Mode?
1. Introduced in Firmware 8.3.0 2. Allows cascading of multiple Peplink devices and combines the number of WANs into a single Peplink device virtually 3. All the WANs on the Synergized Device will appear as native WAN interfaces on the Synergy Controller and it can be managed like the built-in WAN interfacesSample Diagram of Synergy Mode
Synergy Mode Component
Two main components: Synergy Controller and Synergized DeviceSynergized Device (SD) - once activated, it will act as a modem or client device without a management/configuration option
Synergy Controller (SC) - it is the brain to manage and controls all the Synergized Device’s WAN interfaces, including Ethernet WAN, Wi-Fi WAN, and Cellular
Synergy Link (SL) - it is the interconnected link between the Synergized Device and Synergy Controller, and carries both Control Plane and Data Plane
Prerequisites
FIRMWARE: Must be at least 8.3.0 Beta 1 or above, and both SD and SC running the SAME firmware version.
Care Plan: The SC must have an active Care Plan - the system will validate the devices’ subscription prior to activating Synergy Mode. This will allow for Synergy Mode with one compatible device without a Care Plan at no extra cost. Additional SD will need Care Plan as well. This feature will be DISABLED if the SC device’s Care Plan is EXPIRED.
The SC must have at least 1 active WAN (excluding the one for the SL) that can contact InControl 2. Both SD and SC do not need to be added into InControl 2.
Note: The SD firmware has been hardcoded to contact InControl 2 (and feature license server) despite whether it is added to InControl 2 or not.
In both SD and SC, log into the Web GUI, go to System > InControl, and make sure the Controller option is set to “InControl”. This setting must be in the “Enable” state.
The SD must be upgraded to Firmware 8.3.0 and then reset to factory default - do not attempt to make any changes (not even the admin password) when connecting to the SC.
Please make sure you have disabled any existing IC2 provisioned settings on the SD (if any group-level configurations are in place), prior to connecting it to SC.
Models with additional features activated upon PrimeCare activation, should be used with caution.
Supported Models
Synergized Device:
- Balance Series
- MAX Series
- UBR Series
- B One Series
[Update] Removed X Series from Synergized Device list as not all devices in the X Series are currently supported.
Synergy Controller:
- X Series
- Balance Series
- MAX Series
- UBR Series (***Currently only support on UBR Plus)
- B One Series
Firmware
Synergy Mode FAQ
Q. Do both my Synergy Controller and Synergized device require a Care Plan?
To enjoy this amazing feature, the Synergy Controller requires an active Care Plan. This device can then synergize with one compatible device without a Care Plan, at no extra cost.
Q. If my Synergy Controller devices’ Care Plan expires, will the Synergized device still be synergized?
No - If the Care Plan expires then the devices will no longer be synergized. You will need to renew the Care Plan to continue using this feature.
Q. Is there a limit as to how many devices I can synergize with my Synergy Controller?
There is no limit on the number of Synergized devices, it all comes down to how many WAN ports you have available. The first device can be synergized without an active Care Plan, though subsequent devices will need active Care Plans.
If your synergized device has an active Care Plan, then your quota for one (1) Care Plan-free device is still available.
Q. Does Synergized Device support over Virtual VLAN WAN?
Yes - From firmware 8.4.0 onwards, users are able to select VLAN WAN as Synergy Controller - WAN Connection, besides the physical WAN (shown below).
