What is the timeline on 802.11w? WPA3? Sorry in advance I know you guys are busy!
Thanks!
Thanks!
Please stay tuned for the good news
Um… Still “staying tuned”…
Now for 8 months.
Please update wpa3 release.
Umm … Would this be helpful? https://download.peplink.com/resources/firmware-8.1.0-release-notes.pdf. In particular, see reference 22279. Or this? AP One Firmware 3.6.2 / 3.7.3 / 3.8.1 Now in GA .
Thank you for quick reply.
I have upgraded to 8.1.0…
No WPA3 option in any of my current or new WLAN setup pages?
Was the first thing I looked for after the FW upgrade.
Please advise
This is what i saw for my SOHO MK3 device firmware 8,1.0 for the original request for this thread.
Surf SOHO MK3 running 8.1.0.
I will attempt to upload the FW again…
If you have problem to upgrade the SOHO MK3 device, please refer to the forum post below for the firmware that will fix the issue .
Thank you for your help.
I think I’ve got it figured out. Had something to do with my config. If I factory reset the SOHO and then apply the FW upgrade… the wpa3 shows up fine. Then upload saved conf file.
Thanks to all!!!
