Starlink not connected
The port where starlink is connected to Peplink MAX BR2 Pro shows up, but status shows connecting
Just checking did you test the Starlink if there is even a connection? Maybe there is to much blocking?
If not try and assign a virtual WAN to one of the WAN ports and use the starlink on there.
You can find the manual for Virtual WAN ports here with the FAQ:
Sent me a DM if you need some help with that.
Thanks for the response, the issue is now resolved; opened a case with Starlink and they fixed it
Great!
If you have any questions you know where to ask them :slight_smile:
