I just purchased a Pepwave MAX BR1 Mini with Embedded LTE Advanced Modem.
What is the correct Sprint Sim card for the BR1 Mini with the new LTE+ modem ?
I can get a SIMGLW106R Sim Card.
Will this work with the new cell modem ?
Redbarn
Redbarn
Sprint uses a different SIM card for the LTE-A modems and I don’t have the part number in front of me at the moment. Will report back later.
This model is still undergoing the certification testing with an ETA of 2-4 weeks.
Thanks!
The correct part number for these is SIMGLW106Q
Thanks.
My Sprint supplier tells me that the SIMGLW106Q in 2FF size is extremely rare and may not be produced anymore.
Is there another Sim card that will work ?
This is the only one I have ever used and it is not extremely rare but I will check with my Sprint contacts.
Also, does any sim-card will be activated with Peplink IMEI?
I have read on forum that some carrier like AT&T requires a pre-activated sim card, because it is impossible to activate it for Peplink IMEI?
Sprint is the only one that uses a different SIM card for the LTE-A modems. Another thing that is unique about Sprint is that they actually lock an IMEI to a SIM card. In other words, you cannot take an activated Sprint SIM card and place it in another device - it will not work.
And what is about IMEI + sim Lock with other carriers like AT&T, T-Mobile and Verizon?
Sprint is not really doing a SIM lock, this is more like an IMEI lock. I have never heard of any cases where these carriers are using SIM locks.
I meant “IMEI locked with sim”, but not a regular sim-lock.
So, do other carriers lock IMEI to a specific SIM card?
С уважением и
наилучшими пожеланиями,
Заместитель генерального директора
ООО “Кей энд Джи Компани”
ООО “ЛюксКлин”
Гориславец Сергей Романович
моб. +7 (495) 210 4292
e-mail [email protected]
www.luxclean.ru
No, only Sprint is doing that here in the US. I also think this will change in time and you will be able to move a Sprint SIM card from device to device without issue.
Tim,
Could you please post the name of a supplier of the SIMGLW106Q ?
Both my 2 local sprint stores & the Sprint MVNO that I plan to get Sprint service from have told me that they could not obtain the SIMGLW106Q.
Redbarn
My supplier is Sprint internal. I will try to find out more info for you.
We typically have the SIMGLW106Q PCS SIM Cards in stock if you need them.
Tim,
I wanted to add a resource if you have customers looking to purchase the Sprint SIM Card for this device! Let me know if I can help!
This is great, thanks!
For LTE Advanced you need the Sprint “I-SIM” SIMGLW106Q. For LTE you need the “U-SIM” SIMGLW106R.
Can you advise when BR1-mini will support LTE-A formally? Until then, we will continue to use SIMGLW106R for our deployment.
To confirm: when LTE-A is available for BR1-mini and we are using SIMGLW106Q, would the device have the ability to fallback to LTE/3G/Edge?
The BR1 Mini LTE-A is already formally supported but it will not fallback to the 3G networks of Sprint or Verizon as they are using CDMA/EVDO.
Just to clarify, with the BR1 mini LTE-A router I can use either the SIMGLW106R or SIMGLW106Q with the difference of the Q will not have the fallback to 3g? Just wanting to decide which card to get.
