Hi , I am new to Peplink devices. I just want to seek on your advice regarding my concern. My VPN connection to other sites all went down and I don’t know the reason behind. When I checked the internet connection on both HQ and nearby sites , it’s up with good and stable connection.The error says " Not available -link failure detected." After “Updating Routes…” status it will immediately went back to Starting…
Base on the error message and the connection stat “Updating Routes…”, I would suspect that the issue may related to the PepVPN data port is not allowed. Would you please further check on that ?
You can perform packet capture from Peplink devices to confirm the PepVPN traffics is received for both end devices.
