I do not understand SpeedFusion with or without its cloud. Tried to get up to speed a few times, but … no. So, I kicked the tires using a Balance 20x with a single WAN connection.
Its a VPN! who knew? SFC looks like IPsec with an outbound connection to port 4500. A device assigned to SFC gets a new public IP.
My question: Compare and contrast, for a single WAN user, SFC vs. the OpenVPN client.
Specific questions: Who does DNS for a router client assigned to  SFC? Also, I could not find an on/off switch. Is there one? I had to delete all the locations.
Thanks in advance.
SFC is a way to bond multiple connections very very easily. It has lots of clever stuff you can turn on, like WAN smoothing, Forward Error Correction and seamless hot-failover between those multiple Links. For a single link, the primary benefit of SFC is the ability to choose which location to break out to the internet from. The other thing I frequently do is turn on FEC to combat packet loss on a single link. The purpose of SFC is not privacy but application reliability using multiple links (and to a lesser extent bandwidth bonding).
OpenVPN has none of the clever multi-wan stuff as its not multi-wan aware and requires a non Peplink VPN service to be bought and paid for (NordVPN, ExpressVPN, ProtonVPN etc). There are more VPN service providers available globally. Most people use OpenVPN services for privacy purposes I would suspect (and enterprise networks access for those poor networks that don’t have a Peplink yet).
SpeedFusion VPN itself (with a private hub located in your own datacentre or run by you in a public datacentre) is more directly comparable to OpenVPN in that this can be more about privacy and used by enterprises to connect remote staff and their office locations.
Google I suspect.
Deleting locations turns it off. Also you can be more granular about which connections use SFC or not instead of removing the locations.
When using Speedfusion cloud you can bond Wired WAN and WiFi WAN on a SOHO.
