Slow/throttled Speedfusion connection
I’m experiencing a weird Speedfusion issue, hoping for help. Despite being on relatively good/high bandwidth connections, my VPN link is capping at about 6Mbps for transfers and the ping is highly variable causing services to fail occasionally.
Here’s my setup:
Site 1:
Peplink Balance 380
Hardware Revision 6
Firmware 7.1.0 build 2287
WAN is 1Gbps CenturyLink fiber
Site 2:
Pepwave MAX HD2
Hardware Revision 5
Firmware 7.1.0 build 3433
WAN is 80Mbps Verizon Fios cable
On both devices:
Encryption disabled
WAN smoothing disabled
Bandwidth limit disabled
Is there somewhere else I should be looking for what’s limiting/throttling my Speedfusion VPN?
@Benjamin, mostly this maybe related to the point to point available bandwidth compare to the WAN link available speeds. Please open a ticket ticket for support team to check.
https://contact.peplink.com/secure/create-support-ticket.html
