Because of the high output power of repeating amplifiers like the Pro 70, you wouldn’t want to direct connect that to a BR1 as it may damage the modem. You would use an internal panel or dome antenna and place the BR1 within range of that repeated signal, or use a direct connect amplifier like the Signal 4G.
