Will it be possible to transfer configuration settings from a MK2 Surf SOHO to a MK3 Surf SOHO by saving the configuration of the MK2 and having the MK3 read that file? Or are the configuration files incompatible?
Yes. This is supported in v6.4.0 which to be available on year end.
Clarification: FW version 6.4.0 has been re-numbered to FW version 7.0
If you would like to upload a saved configuration file from a previous hardware revision Surf SOHO to the SOHO MK3 the MK3 must be running firmware version 7.0 or higher.
Thank you.
That’s fine, but v6.4/v7.0 was supposed to be released shortly after the holidays. We are now almost half way through January, and v7 is still only a RC.
Is there a date it will be released for production?
@mjburns, sorry for the delay. We fixed a number of bugs and we released RC3 now. RC3 is quite stable, I believe GA firmware should be available soon. Stay tuned!
