Is it possible to run and setup FusionHub on a VM inside a Windows VPS with VMPlayer/Oracle Vbox installed.
Then I would like set up PepVPN and connect my HD4 device to this FusionHub?
Thanks in advance.
Rgerads,
Georgi
Thanks in advance.
Rgerads,
Georgi
Hi Georgi, welcome in the forum, the fusion hub VM can install in different hypervisor , see the following link : Virtual Appliance for Large Enterprises FusionHub- Peplink
Yes you can setup a Pepvpn between HD4 and FH, the important thing is that the wan of the fusion hub has a static public ip or ddns .
to configure a Pepvpn you can read this article : The Quick Guide to Building a SpeedFusion Connection
regards
Antonio
