I’m configuring my Surf SOHO MK3 router, and trying to understand the relationship between the main firewall (Advanced —> Access Rules) and the SSID “Firewall Mode”.
Do SSID Firewall Mode rules augment or override or replace the main firewall rules for the SSID in question? And which rules have higher precedence?
My question overlaps with Surf SOHO Firewall Mode in SSID Settings, but @TK_Liew’s reply on that thread simply described the function of each firewall rule group in isolation, and also described SSID Firewall Mode setting in isolation.
Suppose I have the main firewall configured with rules. What happens in the following scenarios?
- Main firewall configured. SSID Firewall Mode set to Disable. Does this disable all firewall rules for the SSID or does it behave exactly as the main firewall rules specify?
- Main firewall configured. SSID Firewall Mode set to Flexible – Allow all except… Do rules specified here add to the main firewall rules for this SSID, or do they replace the main firewall ruleset for this SSID?
- Main firewall configured. SSID Firewall Mode set to Lockdown – Block all except… Do rules specified here add to the main firewall rules for this SSID, or do they replace the main firewall ruleset to this SSID?
