Reach thermostat on WIFI WAN 10.10.10.10 from the LAN
I have Wifi WAN connected to an AP that’s assigned the peplink 10.10.10.12 On that network at 10.10.10.10 is a thermostat I am trying to reach. I can ping it from the System->Ping menu of the BR1 but I cannot reach it from any LAN clients.
How do I do this?
I tried to add outbound policy
Source Any
Destination 10.10.10.10
Enforced WAN WIFI WAN
Traceroute to 10.10.10.10 shows it’s trying to go through 192.168.50.1 (peplink) but not getting anywhere past that.
traceroute to 10.10.10.12 (10.10.10.12), 30 hops max, 38 byte packets
1 10.10.10.12 (10.10.10.12) 1.504 ms 1.903 ms 1.630 ms
root@einstein:~# traceroute 10.10.10.10
traceroute to 10.10.10.10 (10.10.10.10), 30 hops max, 38 byte packets
1 192.168.50.1 (192.168.50.1) 1.195 ms 1.224 ms 1.312 ms
2 * * *
3 192.168.50.1 (192.168.50.1) 106.661 ms 112.052 ms 133.524 ms
4 * * *
5 192.168.50.1 (192.168.50.1) 213.333 ms 235.290 ms 227.970 ms
6 * *
Check that your wifi settings does not have lan isolation turn on, it may be under a hidden ? icon.
I haven’t seen a setting like that. Where would it be?
Have you setup the wifi via ic2 or locally in the device?
I set it up locally on the web admin
Are you on firmware 8.5? I’m seeing something with 8.5 where a device on a VLAN can’t talk to the router, when I have firewall rules + outbound policy in place. see Outbound Policy + Firewall + VLAN bug in firmware 8.5
Yes I’ll try downgrading to 8.4 but I think my issue isn’t the same as theirs
rolling back to 8.4.1 worked thank you!!! I was going crazy
Interesting! Do you know more about your device?
My IOT device only communicates using UDP. I wonder if that’s relevant?
It’s a MAX BR1 HW3 LTE only no 5G I’ll probably upgrade to 5G now that I’ve proven this concept works. I changed literally no settings just rolled the firmware back to 8.4.1 and I can access everything
Now I have one more request, trying to reach starlink dishy on 192.168.100.1 from local LAN. (peplink can ping it through system->ping) but a LAN device cannot. set an outbound policy for that IP the same as I did for the thermostat but to no avail
Just like this:
Well after a while I stopped being able to reach 10.10.10.10 lol wth
I do see a MAC on 10.10.10.10 when I run support arp
