Hi anyone got encounter DNS resolve issues, where when we dial in the PPTP , we can ping some of the application with hostname , so is not able to ping, not sure the problem is on peplink PPTP or their DNS server, but from their local pc is able to ping all the application with hostname, so is a bit weird.
Can you further explain the following explanation given ?
“we can ping some of the application with hostname , so is not able to ping”
hi sitloongs, sorry type error:
we can ping some of the application with hostname , some is not able to ping.
Please check on the forum post below:
hi sitloongs, I did tried several way:
- Tried set the hostname and IP in the peplink LOCAL DNS Record and DNS point to peplink is not working.
- Tried play around with the DNS suffix is also not working.
Is really weird that some able to resolve some is not.
hi Sitloongs, can I open a ticket with peplink support about this?
As mentioned here, NetBIOS can go through layer 3.
If you are using Peplink LOCAL DNS Record, please ensure all clients point Peplink’s LAN IP as DNS server IP. Alternatively, please use WINS server.
