Being that the new 802.11ac standard is out, I was just wondering if you were thinking about any new Pepwave 802.11ac products any time soon? I’m particularly interested in 802.11ac AP One. I love Pepwave and will definitely wait for one of your products before bying anything else.
I don’t need the higher peak short-range throughput; I need the greater throughput at a longer range. Also, I’m looking to use the higher throughput for local network streaming from the NAS drive I have attached to the router. I’ve tried optimizing my Cradlepoint MBR1400 in every way I can, including the surrounding environment, but I can’t get the speeds I need for HD streaming to rooms that are on the edges of my home. Would you suggest I try attaching an AC access point to the non-AC router for NAS streaming? I think that would be a workaround, but I was just hoping for a cellular router with AC built in so I can use one device. Especially if it has a SIM slot so I can skip the USB or WiFi as WAN connections.
The 11ac products will definitely have a 1 Gbps Ethernet port.
The AP One and AP One mini have 150 Mbps radios with a 100 Mbps Full Duplex Ethernet port, so technically they could do 200 Mbps bi-directional. But do to the overhead of the 802.11 protocol, real-world throughput is generally about half of the PHY data rate. The best I have seen is about 80 Mbps on a 150 Mbps radio.
We are excited about the enthusiasm building around the AP One 11ac product. We promise you it will be awesome.
I very much hope I can share the dates with you now but I’d rather ask for your patience and we will work out the details in the next week or two. We will post more information as they become available.
Thanks for the fast response Keith. Hopefully it will be released very soon since I am very eager to get my hands on one of those for my office, hence all WiFi clients are already upgraded to 11AC standard.
Hi Adrian, are you using any Balance router or AP One devices? Do you plan to use Balance’s AP Controller with the 11ac products? How many 11ac units you’re planning to install in your environment? Or can you briefly describe your deployment scenario?
I have 2 Balance routers , the 20 and 305 versions, also planning to get 1 more above the 305 one.
And yes, the plan is to use these balance routers with the 11AC products you might release , I am interested in the AP One 300M and AP One Flex 300M to use with my balance routers but only once they will have the 11AC.
