Background
Courtesy of a notification from @aungkyaw_khine, multiple vulnerabilities have been identified in the OpenSSH component (< 10.3) embedded in router firmware versions up to 8.5.4 (as highlighted in this post).
A Peplink appliance is only vulnerable if the [CLI SSH & Console] option is enabled under Web Admin > System > Admin Security.
The relevant CVEs associated with the OpenSSH component are:
- CVE-2026-35385
- CVE-2026-35386
- CVE-2026-35387
- CVE-2026-35388
- CVE-2026-35414
Products Affected
These vulnerabilities affect the firmware (up to version 8.5.4) of the following product series:
- Peplink Balance (and Balance with MediaFast)
- MAX
- FusionHub
Mitigation
As a workaround for routers running firmware with an affected OpenSSH version (< 10.3), users can manually disable the [CLI SSH & Console] option if it is currently enabled.
Note: By default, this setting is disabled.
This issue has been resolved in firmware version 8.6.0 GA across the Peplink Balance, MAX, MediaFast, and FusionHub series by upgrading the OpenSSH component to version > 10.3.
The fix is also included in the firmware 8.5.5 maintenance release.
Published: 2026-08-21
Ref.: #36608 (8.6.0) | #37225 (8.5.5)
Credits to: @aungkyaw_khine
