Hi
I have peplink 580 load balancer and i just updated the firmware to 7.1.1 build 2460.
I just need to know if the Temperature of the device is normal.
here is what I found on the dashboard:
Temperature: 51.5 °C / 124.7 °F
Hi
The temp will depend on several factors. What location is the 580 installed in? Is it a closed rack, an open rack, does it have other devices installed around it? Does the room have AC?
What location is the 580 installed in? Is it a closed rack, an open rack?
Its in a closed rack
yes . above it is a cisco switch only.
yes. the AC is set to 18 so the room is cold.
Please refer to the following forum post. That should explained your concerns.
Ahaaaaah, Then its normal .
Thank you
Hi again,
the temperature exceeds 60.0 °C, is it OK?
I also need to know the temperature limits (min value, max value).
Its an intel processor in the B580 I think, so anything under 100 °C and you’ll be fine, although if it runs consistently above 70°C then personally I’d add airflow / cooling.
I’m having these reads(up 56) only when the AC is OFF.
Thanks a lot
