Hello ,
is there any way to login if we loose the admin password of peplink 360 device . Also display interface is disabled .
Hello ,
Hi dizo,
the easiest way to loginto a Peplink device is using InControl. If your device is managed with IC2, you can access the web-admin.
otherwise you should read this
Regards
Dennis
